[NEBULA] Amazon Echo not connecting with NSG Content Filtering enabled
Hi there
I have some new Amazon Echo's in the house that i have to turn off content filtering to get connected. Once connected and working then i turn on content filtering and after 1 day etc the echo's stop working.
This seems to only effect the 2 new ones not the other 3 (older generation) that i have in the house.
When i look at the firewall / content filtering logs i do not see anything denied.
What has changed in the new models over the old one?
Content filtering profile is just the obvious ticks and nothing that looks obvious that would block it.
Any advise as do not want content filtering turned off.
Hello @Hughie
Can you please help me to confirm if there is any relevant Amazon services in Security gateway> NSS analysis report, select as Content filtering.?
Chris
Hi Guys! Same problem as soon as I tried to activate my two new Echo Dot 4.I had to turn Content Filter OFF and I could set them up.There is NO content filtering log.I'm tryng removing "SPAM" from the list, and re-activate the content filter.Brand new NSG2000
update: No luck leaving only Pishing and Malicious sites..I have to deacticate Content Filter until a solution is posted by Amazon or Zyxel Nothing in the logs, but the issue is clearly related to Content FilteringAt the moment, Content Filtering is OFF, Application Patrol is ON, Antivirus is ON, Intrusion detection and Prevention are ON.Another side issue: I have two FTTH WAN1+WAN2, each one 1GB... Speedtest cannot exceed 720 MBs ... no way to achieve the nominal throughput. Shouldn't NGR200 go up to 1,2GBs???I ordered a NSG300 (up to 4GB throughput) for the other Office....let's see....0
Hello @MarcolzWelcome to the community, about the Echo dot4 issue can you activate the support request in Nebula, Help page then I can access to your org. to confirm the setting. (private message me your org. and site name. )I can see you have raise another post for the throughput question, will reply you there.
Chris
Nebula_Chris said:Hello @MarcolzWelcome to the community, about the Echo dot4 issue can you activate the support request in Nebula, Help page then I can access to your org. to confirm the setting. (private message me your org. and site name. )I can see you have raise another post for the throughput question, will reply you there.Thank you Chris! I will activate the ticket as you suggested.0
- 383 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 76 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 894 Nebula FAQ
- 415 Security FAQ
- 233 Switch FAQ
- 205 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
