[NEBULA] 5G WIFI is not accessible
martinihenry
Posts: 18 Freshman Member
Hi community,
I have problems connecting my AP with MacBook Pro, I can see the ssid but could not connect to it. someone can help?
I set my SSID in 5G band, besides that I dont think I've done something wrong.
Hi martinihenry,
I would suggest try to change your 5G channels in the radio settings first see if that helps.
If not, could you check your NAP's country code then check the regulatory of you MacBook see if it does support to operate in that specific country? We have some customers running into the same problem as it could be related.
Check this guide first see if it solves you problems.
FAQ Guide here1
- 383 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 76 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 890 Nebula FAQ
- 415 Security FAQ
- 233 Switch FAQ
- 203 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
