Jason
[NEBULA] NSG 100 - Maximum sessions per host (1000) was exceeded.
Hi @mjr
It's already in our roadmap will be launched in this year, I will update the schedule once confirm of it~
Cheers!Chris
Hi @Nebula_Chris
Good to hear an update for this is coming. I have two NSG100's connected to each other, and I am running frequently, almost daily, into the 1000 session limit per host (in the event log), while I am currently just the only person test using a setup (with less than 20 devices combined over both NSG's).
When it would go into production with this limit of just 1000 sessions per host it wouldn't be so good. So I am quite curious to hear of any news on when or how this limit can be changed (also fine if there is a temporary solution through ssh or )?
The situation occurs naturally (reaching the limit), but when I do a scan on the network to see what is connected, with a tool like Advanced Port Scanner, which helps to see which devices can be seen through the VPN, or do a port scan from the outside to see if no ports are left open by accident, the session limit is reached every time this is done. If there is a smarter way or tool to check this without creating many sessions, any tips on avoiding reaching the limit?
Thanks!
Mike
p.s. or if there is way to kill sessions, that would help, I am now waiting to use the system till the session count is low enough, but easier if I could actively do something about it of course :-)0
Hi @MikyMike,
We have already enhanced the session limit feature on NCC.
You may go to GATEWAY > Configure > Traffic Shaping to configure.
Hope it helps.
- 384 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 77 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 898 Nebula FAQ
- 415 Security FAQ
- 234 Switch FAQ
- 205 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
