[NEBULA] Error: 5G Radio Tx stuck internal reset
Hello @Dirk
"5G Radio Tx stuck internal reset" occurs when the AP is under particular wireless environments. This issue occurs more frequently in channels between 149-165. I recommend moving the 5G Radio to a different channel.
You can manually change the 5GHz channel under AP > Configure > Radio setting.
Change the default channel (DCS) to a channel further away from 149-165. Preferably channels 36-48.
Best regards,
Barney Gregorio0
- 396 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 78 Nebula Status and Incidents
- 5.1K Security
- 51 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 332 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 880 Nebula FAQ
- 415 Security FAQ
- 221 Switch FAQ
- 195 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 72 About Community
- 63 Security Highlight
