[NEBULA] How can I improve WiFi roaming of sticky clients?
Zyxel_Dean
Posts: 237 Zyxel Employee
The answer is to enable Smart steering.
Smart steering is a feature equivalent to RSSI threshold feature of Zyxel's non-nebula APs, where the AP will stop respond or disassociate the client if the RSSI of the client reaches a certain value to encourage the new association to another AP.
How to configure:
Go to Configure > Access points > Radio settings > Smart steering.
Next toggle on the Smart Steering feature.
Disassociate Station Threshold is the minimum kick-off signal strength, AP disconnects the wireless client when its signal is lower than the threshold. You could adjust the value based on the real signal strength monitoring. The client’s signal strength can be monitored at Clients after client connected to AP.
This should allow the access point to guide sticky clients into associating with nearby APs with better signal strength.
How to configure:
- 385 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 75 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 908 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 886 Nebula FAQ
- 415 Security FAQ
- 228 Switch FAQ
- 200 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
